It seems that this contribution has been heard by the development department:
Release notes for January 18th (v4.1.4)
Added option to activate Saved Loop 1 on song load
I was looking for the auto loop cue point feature so I can have it automatically engage like I could in Rekordbox and Serato. However I donât see where I can do this. I would like to have the loop activate automatically and name it Outro for example. So that when I bring in the mix I donât have to activate it manually or switch to saved loops and activate it. Can you show me how I can set this up. I left the other music software cause you guys are by far better. However there certain features they have where I use it all the time.
Hi @FLORIDA_BEAT_MAKERS, Iâve moved this discussion to another more related thread: Enable Saved Loops automatically
I did this. How do I save it as a cue point where I can store it as a cue point and color it. Or this is not possible I would have to click saved loops on mixer then activate it.
@FLORIDA_BEAT_MAKERS, you need to first open the Saved Loops section in djay. Then set your Outro Loop in the #1 slot of the saved loops. Iâve shared a screenshot of how this looks on iOS, but it should be pretty similar on other OSâs.
Thanks. I did this but itâs not engaging automatically when it hits that saved loop. I have to engage it manually.
You need to set the loop then load a different song into that deck. Then reload that same song. This setting only works on Song Loading.
I think I figured it out but it doesnât activate it automatically unless I go to my saved loops and manually activate it. Then when it gets to this point it will engage. I see it does it but a bit differently than the other softwares in Djay.
I thought it did it like Serato where you set the que point then you tell Serato if it is a quĂŠ point or a loop if I click loop it does it automatically without me engaging it.
Thank you for all your help
Youâre welcome @FLORIDA_BEAT_MAKERS. Just reload the track and it should automatically engage the loop without you having to manually activate it in the Saved Loop.
Note that when you are first setting these loops in a track, you need to reload the track into the deck to initially activate the loop. However, all future times that you load the track, the loop will be engaged automatically. This is initiated on Song Loading. So when you first set the loop, you need to reload it to initiate the setting. Hopefully that makes sense.
Yes just did it and it loaded the loop right away. Thank you so much. I was getting frustrated over this feature.
Now if they would allow us to load up our own loops and sync them like Traktors mix decks that would be awesome.
Is this feature iOS only? I donât seem to get it working on the Mac app.
Hi @Almost_Daily, welcome to the Community! This is also available on macOS in the djay Settings>General>Song Loading>Activate Loop.
Thank you, thatâs great
Youâre welcome @Almost_Daily
