Enabling cue at before the first bar
like Serato supports, would it be possible to set the cue before the 1st bar? e.g., I want to set the bar at the -4 bar. It would be useful for playing tunes without intro.
@2katz you can use the Beatgrid Editing tools to set the first bar wherever you like. Then the bar counters will be negative before this point. Follow the numbers in the order shown below:
However, it’s not possible to add a temporary cue or hot cue where there is no audio or waveform.
Thanks for the answer, but that was not I was looking for - I want to set a cue where there is no waveform. Is it too difficult to add the feature?
You’re welcome @2katz. Unfortunately, that is not currently possible. Please use the blue Vote button at the top left so the dev team can gauge user demand for this feature. Thanks!
