- Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro M4
- Version of operating system (e.g. macOS 14.4.1): iOS 18.1
- Version of djay (e.g. 5.1.2): 5.2.3
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Hercules T7 Premium
I am only able to activate one manual effect at a time in djay pro using the default mapping for the T7. In other words, I should be able to use 3 FX at the same time for each deck. There doesn’t seem to be a mapping available for the FX buttons in the midi mapping section. (I.e. pressing each of the 6 fx buttons on the T7 don’t seem to correspond to a midi note.) Am I missing something? Or is this going to come in a future update? Or is this on the Hercules firmware side perhaps?
I betting the problem is me. Please help.
