Hi djay Pro community & Algoriddim team,
Building on my previous feature request about EQ knobs and effects, I wanted to elaborate and clarify my ideas for enhanced controller functionality in djay Pro. I believe these additions would significantly improve creative control and workflow for DJs.
Here are my detailed requests:
1. EQ Knobs as Effect Triggers & Modulators with Dual Functionality (Corrected Behavior):
1.1. Center Position (Default): * The EQ knob (Bass, Mid, or High) functions normally, controlling standard EQ or stem volume (depending on user configuration). * Effect DEACTIVATED.
1.2. Counter-Clockwise Rotation (from center position): * As soon as the knob is rotated counter-clockwise from the center position, the pre-selected effect activates immediately. * The effect remains active (at a constant intensity) as long as the knob is held in any counter-clockwise position. * While the knob is rotated counter-clockwise, it ceases to control EQ or stem volume and only controls effect activation/deactivation.
1.3. Clockwise Rotation (from counter-clockwise position): * As soon as the knob is rotated clockwise from a counter-clockwise position, the effect deactivates immediately. * The knob immediately returns to controlling its normal function (EQ or stem volume), depending on user configuration.
* *Ideally, users could choose which effect is assigned to each knob via a dropdown menu in the settings. "Echo Verb Out" is just one example – the key is flexibility in effect selection.*
