Greetings.
I’m using a Performer and want to have the ability to eq the output from djay pro with adding any external hardware, and leaving the eq knobs on the performer set to neural mix. The main out effect doesn’t work when in external mode.
Anybody have a workflow, or any suggestions?
Hi @DJ_A_Diffrance, you might be able to achieve this on macOS with 3rd party apps like like Audio Hijack paired with Loopback, or SoundSource. They can capture audio out from another app (like djay) and apply a software EQ. I don’t have any experience with Audio Hijack though so I can’t really guide you much further than that. Maybe someone else in the community can chime in with some details. I hope that helps!
Thanks Slak_Jaw. I am trying out audio Hijack now. Will report back later.
You’re welcome! Hopefully that works for you…
