Seems like such a simple thing. It doesn’t exist yet?
Hi @N_C, go to the djay Settings>Sound and change your EQ Type to Isolator.
Alternatively, you can MIDI map EQ kills to available buttons on your hardware using the built-in MIDI Learn tool.
Thanks. Aware of isolater option but you still have to turn the dial, it’s not an instant (and much easier to use) instant kill.
Is there a eq swap feature like drum swap?
What is midi learn tool? Searched manual, nothing. Where do I find info on it?
Hi @N_C, as mentioned above, you can MIDI map buttons on your hardware to EQ kills. You’ll find these near the bottom of the MIDI commands in the MIXER SETTINGS section.
Here’s a link to how to MIDI map on iOS:
