On my macbook 2010, the EQ always resets after reloading a new song, no matter the EQ settings in the menu.
I waited for the update, but the problem is the same.
Reboot did not help.
Thanks in advance.
Hi DJ Ivan,
thank you for pointing this out and your feedback about our latest djay Pro version.
We are working on a fix for this issue and will provide a solution to the issue soon.
Cheers,Lukas E.
