- Device model IPAD 5th gen
- Version of operating system (e.g. macOS 14.4.1): 16.7.11
- Version of djay (e.g. 5.1.2): 5.3.2
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): none yet
Summary of the issue:
I think since the last update? I have not been able to load apple music media onto the decks of the ipad version of djay. Previously this has not been a problem. I noticed there was a similar problem with a previous update which I think had error 400, where the library / streaming became unavailable for some time.
On the same ipad I can stream musci from apple music.
On my mac I can stream from apple music, and load and play files using Djay
How to reproduce the issue:
Have my ipad?
Hi @WarmFire welcome to the Community! Sorry to hear you’re experiencing this issue.
- Please log out of Apple Music streaming from within djay and any other standalone apps or browsers.
- Close djay.
- Perform a Forced Restart of your iPad: Force restart iPad - Apple Support (IE)
- After restarting, disable your VPN if you are using one.
- Launch djay and only log into Apple Music streaming from within this app.
- Retest, and let me know if you still get the same error.
Hi, I am using this app on my Windows laptop. It worked perfectly fine yesterday with Apple music. Today I kept getting this error each 2-3 songs. I did have Apple music open on my browser but I logged out of it. Any tips please? Thanks
Hi @Sruti_Ramnath, welcome to the Community!
- Close djay.
- Perform a Forced Restart of your iOS device:
- iPhone: Force restart iPhone - Apple Support (CA)
- iPad: Force restart iPad - Apple Support (IE)
Hello @Slak_Jaw so I am not using an Apple device. I can still try to do this. But is it different for Windows? Thank you!
You’re welcome @Sruti_Ramnath. Instead of the Forced Restart step, simply reboot your Windows device. All other steps remain the same on Windows.
