Macbook Air M4 , 24GB ram - Latest OS
Problem : i’m working , all OK but in one moment I can’t load songs
The popup says : ERROR OSSTATUS - 54
RESTART the Mac works … but then again i have the same problem
Hi @Mauri_Moore, sorry to hear you’re experiencing this issue.
Djay pro 5,3.1
Local music , internal ssd (2TB) , mp3 & aiff files .
Thanks @Mauri_Moore, can you please upload some of the songs you are having issues with along with your djay Media Library database to your Google Drive/Dropbox, enable sharing permissions and share a link to the files with me in a DM?
On macOS, the database file can be found in ~/Music>djay.
Hi again @Mauri_Moore,
Hi : i tried to replicate the problem but now is all ok … maybe was a problem with itunes + icloud … thanks !
Thanks for the follow up @Mauri_Moore
