Hello, does anyone have this error message “Error starting audio engine the parameter is incorrect(-2147024809)” . I am unable get sound through the USB all other controls work fine using the American Audio VMS 5.
Hi Pete,
thank you for your post.
Can you please attach a screenshot of the error and also tell us which djay version and device you are using?
Thank you in advance.
Hi Thom,
I am sorry to hear that.
Please contact us directly via support@algoriddim.com and send us a screenshot of the mentioned error.
Hello Pete.
I have exactly the same problem with using Numark Party Mix as Controller. The same error number.
Who can help?
Greets Thom
what can we do, to solve this?
