Expand the library automatically
  1. Hi guys, I’d love for the Algoriddim team to implement this very useful feature, where when you move the track search wheel, the library automatically expands to full screen, allowing for a better search for the next album to play.
    Once loaded, or alternatively, after 2 seconds without moving the wheel, the standard view automatically reverts to the decks and track waveform.
    I use this option with x1 on Traktor, where it’s included by default and doesn’t even need to be mapped, and it helps me a lot in quickly finding the next track.
    It would be great if it were implemented in the next update as well.
Thanks for the suggestion @Screma. I’ll share this with our devs for consideration.
Come on guys, vote :slight_smile: this function is very useful!!!
yes but not enabled by default
Thanks for the input @Francecorre
Of course, like all features, it should be something that can be turned on or off depending on the user’s preference.
:heart:
Voted for more traction!
I have always longed for this function. The library tab is by default very tiny, no matter how many tabs you deactivate. Having to reach to the laptop twice everytime you find a track to expand and collapse the library is counterintuitive.
For guys who use controllers, please vote!
I dig this. Voted.
Thanks for the input and votes @Armigo and @Austinjacobm94
