Not Sure how to export song data (cuepoints, settings, etc.) from DJAY 1 to DJAY 2. Just upgraded to an iphone 6 plus and unfortunately the old DJAY version is no longer supported unless I missed something.
Any help would be immensely appreciated!!
Merci!!
Warren
October 23, 2014, 9:51am
2
The cue points and other user-generated data usually gets automatically synced if your have iCloud sync enabled on both iOS devices.
Do you still have your iPhone 5? If yes, please try the following:
Install djay 2 on your iPhone 5 as well
load your songs in djay 2 on your iPhone 5 and check if you can see your cue points
go back to the homescreen but do not quit the app (djay syncs to iCloud while in background)
If you can see your cue points in djay 2 on your iPhone 5:
Install djay 2 on your iPhone 6
enable iCloud sync
then your cue points should transfer over as well
Please note that iCloud sync can sometimes take a few minutes. So, if it doesn’t show up just quit djay and try again in a few minutes.
