I just did my first radio show using djay PRO AI vs. djay PRO 2. The show went well, only problem now is that I can’t find the option to export the playlist as either an Aplle Music playlist or as a CSV. Has this option been moved, or removed? Thanks…
You can still export your history as a CSV, but there is no way of exporting playlists themselves.
Ah interesting, thanks. I see now that the usual option to export playlists didn’t show up because in my case I didn’t change my playlist order from what was already in a playlist. Much obliged for your input.
2 posts were merged into an existing topic: Export Playlist (same as export session)
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
