Export playlist to folder
Creating a folder with all the files of a particular playlist
This feature will really help me especially for playing with the android app the playlist i created in windows
Afcourse it will help if it will also create the m3u file.
And it will be especially helpful if it can create a file that the android app can use to add the cue points.
It will also be helpful for backups. If i just want to backup the playlists.
And also when I dj its good to know that if my laptop fails for some reason i can still plug my phone and use the same playlists.
I will really appreciate this feature.
Please vote for this :pray:
Yes, these would be great features to have!
Notes:
Current workaround is to copy/paste the playlist into Apple Music. In Apple Music, you can drag the files into a folder and also export the playlist to a .m3u file. It’s a lot of extra work.
Thanks,
I tried to do it but couldn’t.
In Djpro i went to the playlist press “ctrl a” to select all tracks and then “ctrl c” to copy
then in apple music I created playlist pressed on the 3 dots and choose v for paste but nothing happened
(just to remained you I’m using windows and have no subscription to apple music)
Also can you please vote
Thanks for the suggestion @dimension7. I’ll share this with the dev team. Thanks for the potential workaround as well @Michael_Wisniewski.
I will also appreciate this feature especially if it can add the cue points “create a file that the android app can use to add the cue points.” as I dj sometimes with pc and sometimes with the app.
