It seems you can’t add local music playlists to USB from iTunes (Music.app).
Is that correct? Will support be added for that?
Hi @rishi, please refer to the attached FAQ and let me know if this helps or not:
https://help.algoriddim.com/hc/en-us/articles/23070080061212-Using-OneLibrary-in-djay
Thanks. I understand how it works.
Currently, it seems DJAY only supports export to USB from MyCollection.
If I right click on a MyCollection playlist I can export to USB
There is no right click option from LocalMusic playlists.
Hence, my question will there be support for this?
I can achieve this with Rekordbox, but would prefer to just use DJAY for prep and DJ’ing.
Hi @rishi, currently this is only supported from My Collection. However, I have changed your topic from a Question to a Suggestion. I will share this with the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Thanks @Slak_Jaw … voted
You’re welcome @rishi
