Exporting Cue Points from djay iOS app to djay Pro Mac
Hi
Anyone know if there is an easy way to export Cue Points from djay iOS app to djay Pro Mac. I haven’t seen how to do this anywhere, only the other way around.
I’ve been using the iOS version and have all my cue points stored there.
Thanks :slight_smile:
Hi
Cue points are synched through iCloud. Just enable it on the Djay app and on the Mac app.
Regards
Hi @Donall_O_Cleirigh,
Yes, you can use iCloud Sync to sync your Cue Points accross multiple iOS devices and Macs. You can find more information about this in our FAQ section.
Just make sure you are using the same Apple ID on all your devices.
If you have any other questions, please don’t hesitate to contact us again.
Great thanks, that will sort it
