how do you export mixes in itunes 12.01.26, the file sharing section is not there anymore and there does not seem to be any options that help when you double click
Hi Paul,
Please try the following:
- click on the iPad/iPhone symbol on the upper menu bar
- in the left tab, select “Apps”
- then on the right, scroll all the way down to see the File Sharing section.
This reply was created from a merged topic originally titled exporting mixes to itunes 12.01.26.
