Hi i’m very happy to use DJAY 2 whit my ipad mini2 and MIXTOUR RELOOP but i would like to know if i can improve the quality of output audio with an external sound card and if I’m forced to use filter and effect at the same time, i would like to use only the effect from the controller, thanks you.
Hi Ernesto,
thank you for your post.
In which external soundcard are you interested in? Also I am sorry to tell you that in djay for iOS you are unable to change the persisting mapping of the supported controllers, therefore any changes to the FX button are not possible.
