do I understand correctly that there is no option to listen to your pre-cueing through an external soundcard on windows?
Everytime I connect my external soundcard while I want to use it for pre-cueing, DJay Pro just gives the option to use this one as the only soundcard.
Is there a solution to this problem? There has to be a way to properly pre-cue your sound…
Thanks.
