Ever since some updates ago, the good old rock classic Eye Of The Tiger stopped syncing to a beat perfectly.
Is there a way to use the old sync version on a specific song?
I am on Mac, iPhone and iPad. With or without a controller.
Yes, but straight is not the old one. It’s just straight
The 3 off-beat punches befor the drums messes it up. This can be fixed in other software, but Djay does not have an editor for this. As far as I can tell. Many this should go as a bug instead of a question.
But you are of course right about this. Straight is better in this case.
