- Device model MacBook Pro M1
- Version of operating system 14.5
- Version of djay 5.1.7
- Hardware/controllers used NA
I still occasionally try to load a track on the active deck during a gig. The warning pop-up can now be cleared with esc, which is a big improvement, thanks.
Next improvement step would be to clear the pop-up upon the next midi command from the controller.
Cheers, Bart.
