Would love the option for custom colors so I can color code the different types of cues. Thank you!!
Hi @cmilecki,
Thank you for getting in touch and welcome to our new community.
We added your feature to our issue tracking system and want to thank you for pointing it out.
Adding it too. In the past, the colors of the 8 cue points in DJay Pro used to match with the colors of the cue points of my Reloop Mixon 4. I recently noticed that they no longer match, not sure in which version this was changed. It would be really great if there was a way to customize the colors in Djay Pro AI (Currently running DJay Pro AI 3.0.9).
Same here, would also like that, along with the ability to name the cue points.
Yes - would be amazing if we could name them too!
You can already assign a name to cues to replace the time stamp - not sure what you are asking for…
Naming only works on macOS, not on iOS.
Good point. I forgot to mention that my original request to change the colors for cues to match the one of the physical buttons was for the MacOS version …
