I recently switched from Rekordbox to Djay Pro and have been very impressed. However, I believe adding a track matching feature would be extremely beneficial. These are basically tracks that the DJ thinks go well together.
Here are the key aspects of the requested feature:
Track Pairing Memory: Allow users to save pairs of tracks that complement each other. For instance, if I determine that Track A and Track B go well together, I should be able to save this pairing within the software.
Bidirectional Suggestions: The software should be able to suggest the complementary track when either track in a saved pair is loaded. For example, if I load Track A, it should suggest Track B, and vice versa.
Multiple Pairings: Support for multiple pairings would be highly beneficial. This would allow a single track to be paired with several others. For example, I should be able to save that Track A goes well with Tracks B, C, and D.
Thanks for your reply, but the feature I’m suggesting is different. It’s like the ‘related tracks’ or the ‘match tracks’ in Rekordbox. It’s not the DJ asking the software to find tracks that go well together, rather the DJ telling Algoriddim to remember that track A matches with track B. And in the future if the djay plays track A, they can look at the list of ‘related tracks’ and see B.
Thanks for clarifying @Roozbeh. This feature also exists in djay on macOS. It’s called Related tracks.
Just select the extra screen on the right
Select the track where you want to relate another track to
Go to the info icon.
Select the Related tab and drop the song here that you want to relate to…
From now on it remembers this track combination (it can even remember more related tracks). They link vice versa. So, as soon as you add a related track to one, it becomes visible on the other as well. And once related they also become visible as first in the Matching tracks tab.
Oh wow, I had no idea this was a thing, I would love to see this on Windows! I really hope that both versions will offer identical functionality in the near future
Create a new folder on your desktop (somewhere easy to locate) with a copy of every track in your desired playlist.
Create a new user for your mac
Sign into your App Store download DJ pro but do not add any music previously stored, do not sign into any streaming platforms etc
Using a separate Apple device, I used my iPhone, go into files and locate the new folder containing all of your playlist’s tracks
Share/AirDrop folder to your Mac (logged into the new user)
In DJ pro select “my files” on the bottom left toggle where usually your streaming platforms would be logged in
Click the + and add the new folder
Right click the folder which is now added to “my files” and click add to my collection
You will now notice when you start to play your set and hit the match feature, the feature is now limited to tracks from your playlist only.
Sure it’s a slightly tedious process, but the outcome was exactly what everyone seemed to be after. (Yes I am fully aware that this fails after one playlist unless constantly removing/adding tracks from your new folder). But HOPEFULLY BY THEN THE DEVS TEAM AT ALGORIDDIM CAN SORT THEIR ISH OUT
