There are a handful of features that are either missing or I haven’t figured out how to make them happen. Someone please help me with the following basic things:
Auto-Mix shuffle doesn’t actually shuffle the songs.
I want to be able to pre-cue a song OFF a deck. Many other DJ software systems have a mini player attached to the playlist area where you can preview a song and set its cue points without having to take your on-deck song off. This is a huge flaw.
I want the history to persist across sessions of djay. So often I’ll forget to export my history after a set and then it’s gone… What a waste!
There should be the ability to set the cross-fade duration for auto-mix.
