Hey Guys, Just purchased the Vestax Spin 2 and using it with djay on my Mac & ipad. If it’s a small gig I will just take the ipad & Vestax.
Few questions related to Midi:
The Samples on the ipad are coming in WAY too loud. Can I change the level ? Infact, can I change the samples altogether ?
Is there a quick way to toggle between waveform view while playing. ie. whole song and running view. Can I set a midi button for this (when using my ipad & Mac) I can’t seem to find a solution.
Can I map ‘In & Out’ loop buttons for Mac and ipad ? can’t seem to find a solution.
Thanks in advance, JW
