Dear Sir,
i would like to report some bugs and propositions about Djay Pro 2 - Mac Os!
- Would like to have the ability to switch off the resonance effect on decks filters - it distorts and destroys the sound, it sounds really bad on any sound system(Studio monitors, PA systems) etc. It would be nice to have the ability to turn off the resonator totally!
- Would like to have the ability to use the Audio Units effects on each deck separately and to map them to my controller! It’s useless to have all these effects on master only and toggle them only using mouse and trackpad!
- Would like to have the ability to choose what resets every time i drop a new track on deck. PLease separate the eq reseting from effects section reseting.
- Please add the ability to export and import playlists to my library.
- On my 13” Mac book the interface is not easy to use because my screen is too small to fit all the information - when i open tools, tools bar and sampler the software becomes difficult to use as i can’t see and use my main library any more. It would be nice to fix this somehow! As i see the interface is more usable on touchscreen systems.
- Please add sync and loop function on my user samples - not the one you added on loopmeister!
- As i mentioned earlier please fix the bug that stops the playback when use the swipe scratch function. Please add the ability to turn off the finger swipe scratch mode.
