Why isn’t just the regular “filter” effect included in the “essentials” tab of effects? I am using the old Wego 3 and i like the fact that you can use the jogs to control all the effects, but “filter” is not included,
thanks!
thanks!
Hi @Timothy_Refile,
The HP/LP-Filter is not included in the FX section of the app, you can find this knob on the mixer/EQ-section.
You could, however, map any MIDI action to any MIDI command by following our guide here:
on iOS:
on Mac:
Let me know if you have any other questions.
