Filter for individual STEMs
Option for the filter to filter individual stems, so we can filter only one or 2 or 3 stems. you can add a menu where we can choose which stems to filter. I think it will be especially cool using it with the fx pads.
Thanks for the suggestion @dimension7. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature.
I’d also like to share some existing options which might work for you. There are several Filter FX options available that you can then assign to individual STEMS (Lowpass, Highpass, Bandpass, Auto Filter and Lofi).
Thanks I know about the filter fx.
I have a small change to my request instead of a menu i think it would be belter to have four small icons that you can check.
I think also for the fx instead of choosing the stem in the drop down menu it would be better to have 4 small icons for each fx that you can check, even check more than one stem so the fx can be on 2 tor 3 stems. Then it will also very convenient to change quickly which stem is affected.
You’re welcome @dimension7. Thanks for the additional info.
I’m glad I found this and didn’t have to create a new topic. For some time now, I’ve been wanting a filter that can be applied to all stem channels except vocals, so I strongly upvote this request. Metioned effects for filter do the job but is not easy to use; if you could make it work with a filter knob, that would be much better.
Thanks for the additional feedback @Akrilovy
Hello Algoriddim team! I didn’t see this suggestion already, so apologies if it exists already. I love mixing with stems in DJay. I’ve even mapped out some knobs and buttons on my hardware to make this easier to do! What I would LOVE, however, is to be able to take the Neural Mix feature slightly farther. While I do see that I can separately apply FX to Drums/Inst/Vox, I would love to be able to apply the Filter to each stem separately. I don’t think this should have to be an FX option, but rather another control for MIDI just like Neural Volume and Neural EQ. It would be great to fine-tune mixes by having just the instrumental ā€œmeltā€ away as I turn down the filter, while keeping drums and Vox going strong, for example. It seems that the ingredients for this kind of feature exist already, and just need to be ā€˜put together’ in that specific way. Maybe that’s making a complicated thing sound easy. I understand that having multiple filters, vs 1 for the whole deck, could consume 2, 3, or 4x the processing power for each stem, but I think it could be a great feature add!
Hi @jakemprice I believe what you are asking is already in the Instant FX section, at least I’m using it for the same purpose.
Even tho arguably it still miss more customization features as it is it’s already pretty powerful and enjoyable.
GIve it a look
Hi @jakemprice, welcome to the Community! Thanks for the additional suggestion. I’ve merged this one as well with an existing one. Please vote a the top left. Thanks!
