As a user, I want to be able to search for songs in my library that are unplayable.
Hi @ncianca,
That sounds like a very interesting idea!
May I ask why you’d like to be able to search for “unplayable” tracks in djay?
If I need to remove tracks that were added from a source, there is no way to select those tracks to remove them:
Use Case:
- Add songs from a service, such as BeatSource, Tidal.
- Add some/all those songs from BeatSource with purchased music (e.g. iTunes/actual files)
- Remove the original BeatSource songs so that only the iTunes ones are left.
Hi @ncianca,
Thank you for following up with us regarding your use case.
I will be sure to send this additional information to our team as well!
