Filtering unplayed tracks
If filter is set to display 0 plays no results are visible. What should happen is that all unplayed tracks should be seen. Same goes for setting the filter to “less than 1”
:v:/Jacob
Thanks for sharing @Kushman. I have forwarded it to the engineering team for review and comment.
Hi @Kushman, sorry for the delayed response. The engineering team has a few follow up questions:
  1. iOS device (ex. 2020 iPad Air, 4th Gen):
  2. iOS version (ex.17.3.1):
  3. If you haven’t already done so, can you please update to djay 5.1.2 and confirm if the issue still exists?
Hi @Slak_Jaw
Issue persists. Here’s the info and the outcome:
There are several unplayed tracks in this list that should appear.
Very best/J
Thanks for the additional info @Kushman
