- Please also consider sharing a short video or screenshots to help clarify your suggestion
YOUR SUGGESTION:
We have option to show/hide library sources as discussed in manual
Suggestion option 1 is that if I hide something in “my libraries sources”, the “My Collection” view should follow the same hiding rule. Like hiding spotify source, will hide spotify songs in “My collection” as well.
Another way to do it: add filtering options.
“My Library” and then there would be list of library sources, which could be enabled or disabled.
Why:
As when I’m practicing mixing home, I could have Tidal enabled, but if I’m on gig performing off-line, there is no way to hide “non-available” songs in MyCollection view, they are just grayed out.
I prefer using only my collection, as the split library/sources views are clumsy.
