It could be very efficient to have a fixed Neural mix bar (i.e. the upper part of the Neural section) above the performance sections (cue / FX / loop /…) for touch screens devices.
In order to be able to trigger solo/mute stem and something else at he same time, without changing section.
Tony.
Hi @DJTonyBlanck, thanks for the suggestion @DJTonyBlanck. Do these existing NM controls meet your needs or would you need something different?
Hi @Slak_Jaw thx for this suggestion, I will try to use it that way.
My initial idea was to have the bar with solo/mute stems buttons above and performance functions below.
Tony.
You’re welcome @DJTonyBlanck. Please test it out and let me know what you think.
