Brand-new iPad 128.
Latest iOS 6.13
16000 tracks loaded from iTunes
Pioneer DDJ-wego With latest firmware.
Plugged into 10 watt iPad AC adapter
I was spinning live in front of for 300+ people. With nothing but the iPad and DJay
Everything was working fine, then I heard weird static distortion and then it stopped working It’s seem to just fizzle out like someone pulled the power on an old tube amp
I forced close the program relaunched and it worked again.
This crash happened twice in the night I was down for maybe 40 seconds of dead air with no backup
At the end of the night, The controller stopped responding Completely. But I was able to use the onscreen just finished the last song No one noticed that.
I really want this to work. I don’t want to use any other software on the iPad
I can’t stand traktor. Mixvibes cross doesnt support controllers
Questions:
Has anyone seen this problem before?
Is there a log I can send? How do I send it to you?
Are there any other controllers that are more stable than the Wego?
Other Observations:
I keep having to turn on the master tempo every time I load the track This is ridiculous. Why is it not an option?
Can’t quite read the full title it cuts it off Especially bad when you have a different versions of the same song They all looked same.
No Way to see the key when browsing the record case
I wish that it remembered the sort by BPM every time I go into the record case
Aside from that, it worked out quite well
Wirelessdj
