Flux Go, iPad 9th gen, charging adapter / hub
Hello,
Is there a hub that will transfer data from the iPad(9th gen) to the Flux Go and charge the IPad? I am having trouble finding a solid answer online.
Thanks very much for any guidance!!
YOUR QUESTION:
  1. Hello, is there a job that will transfer data and charge and iPad while using
Hi, there is an apple camera connection cable that will do that job.
Edit: seems they are only for lightning connectors. If yours is USB-C then look for a hub with charging pass through, loads on Amazon
Hi @Keith_Foley, welcome to the Community! @STU-C is correct. Since the 9th Gen iPad uses a Lightning connector, I highly recommend you stick with the genuine Apple adapter as many of the 3rd party ones are unreliable.
Thank you both so much for the fast responses and pointing me in the right direction!
You’re welcome @Keith_Foley. Happy to help!
