FLX10 FX and Hot Cue issues (iOS)
So glad I didn’t purchase the flx10. To be honest. This new compatibility is worse! Most things don’t work with the iPad now…, You are stuckonly using hot cues because you can’t change frrom that.. the on board effects don’t work. The channel effects don’t work. Crazy! So djay only works with my entry level controllers😡. This is crazy.
Hi @Five-0, sorry to hear you’re experiencing these issues with the FLX10 on iOS. Can you please provide more details about the issues and your setup? Preferably a short video as well? It sounds like this might deserve its own topic. I want to make sure these are clearly communicated to the dev team. Thanks!
Hey man. Can you share what issues you’re having. I have a fix 10 and have iPad and Mac. I can help also with any testing or trouble shooting with you.
iPad iOS version 18,5 iPad Pro 11 inch 4 th gen. Djay pro5.4.2. On board effects didn’t work. Channel Fx with filter don’t works & I couldn’t change from the hot cue page
I only use it once a week . I just posted of video of my issues with the ipad
Hi mate, just check your mappings. I’ve had a similar thing. Could be a bug with custom mappings. If you have several mappings delete them and just leave one or go back to original mapping and see if that’s better. I had 2 mappings that were some how conflicting.
Ok the next time I’m at the club I will try :folded_hands:. For the Mac The dev team confirmed my issue will need a firmware upgrade from pioneer. The digital marker in the display screen does not snap to the 12 o’clock position like all other hardware
Ahh got you. Is the device not on the latest firmware?
I had the same issue yesterday when trying to re-create my midi mappings … but suddenly it worked, don’t know what i did except for shutting on/off and plugging in/out. Did not do a restart of my iPad, though
I remember that I first used my old mappings and then switched to the default mappings … maybe that was the solution, but I am not sure
It is the latest firmware for the flx10. They need to do a new one because djay can’t change it on their end which baffles me. Because the digit marker was the only thing working on the screens before the update and it was perfect
Apologies for the delayed response @Five-0! I’ve been a bit behind after a very busy August. Thanks for the video and setup details. This is very helpful. I have shared these with our hardware team to see if they can replicate this. When you get a chance, please confirm if you are using the (built-in) MIDI mapping or a custom edit.
Also, thanks to @Dysfunk_DJ and @turbopussy for the help on this one. I really appreciate it!
I was using my edited one that I made a few months ago
I would use the default mapping and try again. Worked for me. Some
individual mapping may be implemented again
Hi again @Five-0, just following up to see if you were able to replicate this issue with the (built-in) MIDI mapping. Our hardware team tested this extensively and could not reproduce this on their setup. Thanks!
I’ll have a chance Saturday to test it.
Just use the built in mapping and see how you go.
I will Saturday when I get a chance to use it again🙏
Hi @Five-0, just follow up on this one. Did you get a chance to confirm if the (built-in) mapping works as expected? Thanks!
Sorry . The venue was so busy I didn’t get a chance to try the iPad .
