FLX10 FX1 changes when cycling deck FX assignment
  • Device model iPad Pro 13” 6th Gen
  • Version of operating system 18.4
  • Version of djay (e.g. 5.5.1
  • Hardware/controllers used FLX10
  • Hardware firmware version ?
I’ve tested this and it also happens when I change to channel 3 or four and then change back to one or two.
Thanks for the video and setup details @Nubium - very helpful. This looks like unexpected behavior to me. I’ve passed this onto our hardware team to see if they can reproduce it.
In the meantime,
  1. Can you please confirm that you are using the FLX10 (built-in) MIDI mapping and not a custom edit?
  2. Can you also please make sure you are running the latest FLX10 firmware version 1.14 from Pioneer DJ? https://support.pioneerdj.com/hc/en-us/sections/16716135406233-Firmware-Update
Hi again @Nubium,
  1. If you switch djay to Pro Mode instead of hardware mode and enable the Manual FX View, does the issue also occur there on FX1?
  2. Is this issue occurring on both Deck 1 and Deck 2? Thanks!
Hi again @Nubium, our engineering team was able to reproduce this and they’re investigating further. I’ll share more updates when I have them.
Fantastic thanks so much
You’re welcome @Nubium
