Device model Iphone 14 Pro
Version of operating system Latest iOS 17
Version of djay (e.g. 5.1.2): Latest version for iOS
Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Pioneer DDJ-FLX10
How are you all connecting your FLX10 to iOS? I’ve tried on iPad and iPhone and for some reason the controller doesn’t recognize my phone/ipad? Music comes out of my phone and the controller doesn’t seem to talk to the device. I tried both ports A and B on the back of the unit. I’m using an original apple USB-C to lighting cable. It seems to work with DDJ-FLX4.
Any stems that I must to do make them work together? Planning on having iOS just as a backup, as I primaryl use Djay on Mac with the FLX10. Thanks!
Hi @djchase, is suspect this issue is with your USB-C to Lightning cable. I would first try performing a Forced Restart of your iPhone using the procedure linked below and then connecting with a different genuine Apple USB-C to Lightning cable. If that doesn’t work then, you may need to consider using a Genuine Apple Camera Adapter and connecting with the procedure below. I hope that helps!
Disconnect all cables and adapters from your iPhone and DJ controller.
