FLX10 with iPad
Hello everyone,
I would like to know if the flx10 can work with iOS and Djay on an ipad and if yes, are there missing functions or everything works fine (stems, effects,…)?
I don’t have any computer, only an ipad, and I’m trying to find a controller which is fully usable with ipad.
What are your suggestions?
Hi @catherine_srd, welcome to the Community! Yes, the FLX10 is supported on iOS and iPad. However, the jogwheel screens are not supported on iOS. These are only supported on macOS and Windows. I hope that helps!
Are these the only features that are missing?
Which controler would you recommand the best to use with ipad and Djay?
Thanks again for your feedback :grinning_face:
You’re welcome @catherine_srd. As far as I know, yes.
Another great controller option for djay on iPad is the Reloop Mixon 8 Pro. I personally own this controller and the integration with djay is excellent. Plus it has a built-in iPad holder/slot. Also, the jogwheel screens on the Mixon 8 Pro work with djay on iOS.
If you search through this community, you should find other controller options and user feedback on them. I hope that helps!
Thanks for the advice, and one last question, what do you think about the new rane one mk2?
Thank you for your answer, and have a nice day :grinning_face:
You’re welcome. The RANE One MK2 looks like a great controller. I’ve never used one though so I can’t share any detailed opinions. You might also want to check out the Pioneer DJ GRV6. Have a nice day as well!
There’s also this existing topic where you could post your questions:
A big thanks for your answers guys!
Have a nice day :grinning_face:
You’re welcome @catherine_srd. Have a great day as well!
Are there any plans to adding jog wheel screen support?
Hi @steve_guzman, welcome to the Community! I believe this is currently an iOS and hardware limitation.
