FLX4 Mic Level MIDI name
Hi guys i need to know whats the name on the mic level knob y want to map that knob and i dont know the name for the midi thank uuu
Hi @EL-AREPUS, I don’t have access to this hardware to check myself. However, if the Mic Level knob sends MIDI commands you should be able to figure out the name using the MIDI Learn tool built into djay or by connecting to a computer and using the MIDI Monitor app. I hope that helps!
https://help.algoriddim.com/hc/en-us/articles/360016055199-How-do-I-MIDI-map-a-controller-on-djay-for-iOS
the problem is that knob doesnt send midi commads , thats why im asking :frowning:
Thanks for confirming @EL-AREPUS. If it doesn’t send MIDI signals this knob cannot be mapped.
