FLX4 Neural Mix Button
Device model - Samsung Galaxy Tab S9 + FLX4 Controller
Hello, I am trying to figure out what the midi mapping is set to to use the Neural Mix on FLX4. Thank you.
One bonus question: When I change the beat jump settings, the change doesn’t actually take effect in the beat jump midi pads, and it is still set to default. Any assistance would be geatly appreciated. Thank you.
Bump. Trying to figure out how to use neural mix with FLX4 as I can’t remap on android. Thank you.
I don’t think you can remap on android.
Yeah I don’t think so. Wondering if there is a default mapped button
Hi @saw, sorry for the delayed reply. I had to double check with our hardware team as I don’t have a FLX4 to check for myself.
The only way to access Neural Mix with the FLX4 is to switch the EQs to Neural Mix EQ in the mixer section via the onscreen controls. If they’re set to Neural Mix EQ, the EQ knobs on the FLX4 will manipulate the NM stems.
The Beat Jump performance pads are hardcoded to -1, +1, -2, +2, -4, +4, -8, +8. Changing the Beat Jump settings won’t change these mappings.
Also, MIDI mapping is not currently supported on Android. I hope that helps!
