I’m using Djay PRO on Windows 11.
I urgently need to use FLX4,
It seems that Pioneer doesn’t provide ASIO drivers, so is it possible to use flx4 with Djay via ASIO?
Maybe it’s only WASPI?
flx4 is connected via ASIO to the record box.
Hi @megamema, no you cannot use the FLX4 with ASIO on Windows 11. This is a USB Class Compliant device, so it relies exclusively on Windows’ standard audio driver (WASPI). The Windows standard audio driver will be automatically installed when DDJ-FLX4 is connected to your PC with a USB cable.
I get it. So ASIO can’t be used.
Thanks for letting me know.
You’re welcome @megamema
