Hi everyone, I have the opportunity to get the FLX6 at a good price,
I wanted to know how will work the FLX6 Merge FX mapped with Djay Pro ?
Thanks a lot for your help
Best
Justine
Best
Justine
Hi @JustineB, sorry for the delayed reply. I see that you’ve created 2 topics for the same question so I have merged them together. I don’t have access to a FLX6 to check the Merge FX MIDI mapping so I’ve forwarded your question to our engineering team. I’ll report back as soon as I have an answer from them. Thanks!
Thank you so much! ![]()
You’re welcome @JustineB
Hi @JustineB, the Merge FX button is mapped similar to the Rekordbox merge FX.
- You can select from 4 preset FX chains (not editable) using the small button. They use FX from the “Macro Up” section in djay.
- Pressing the big knob for the first time activates a rising FX and you can turn the dial to heighten the intensity
- Pressing the big knob a second time triggers a reverb/echo out
- Pressing the big knob a third time deactivates the FX to go back to normal playback
Thank you for your reply. So you just can set up one preset ?
Thank you @Slak_Jaw ![]()
One more question please about “Pressing the big knob a second time triggers a reverb/echo out”
Can we assign a sample in the mapping ?
Thanks again
Hi @JustineB, no that is not currently possible.
