Hey @Slak_Jaw and @NathanielAlgo , can the subfolders and categories get a fix to them?
So if i make subfolders it creates the little arrow next to the folder to click on and expand. I feel like its a bit annoying to put the mouse exactly on the arrow. We should be able to just one click on the folders title to open and close it. Instead, double clicking the folder name makes it edit the folder name. If you right click, it also lets you edit the folder name. Right click to edit seems like the best way to edit the name. One left click or double left clicking the name should open the folder.
Can this be fixed?
Lastly, the categories in crates where you can display the song, bpm etc. Can a category be added that shows what format its in? For example, itunes allows you to select diff categories and one of them shows what format the song is such as mp3, m4a etc.
Can that be added so we can see ahead of time the quality or the format of the track?
Thanks yall!
