While making a video for the other thread, I came to this repoducable bug. If in 4 deck mode you hit shift load (deck 4) a menu opens similar to loading a track. If you then switch views (4 deck to sampler to classic to two deck etc.) via shift load (deck 3) the menu goes grey but remains. And if you switch further the app force closes…
Here a video:
https://drive.google.com/file/d/1IGbi…
Also I found that the cue point can’t be deleted via shift cue if the cue is at the beginning of the track.
In the performance section the instant fx used to be on the 2nd layer of loop roll, now nothing happens if you press those.
