Would it be possible to have an option where you allocate a ‘pad’ to a forced stop instead of a cue.
Maybe have it as drop down option, so the pad works as cue point unless you choose to change its function to a forced stop.
So why a forced stop. I guess this is a bit like a saved loop. But there are certain tracks where i want to exit at a certain point. If i could use a forced stop it would make things simpler.
I have a mix i like to do, which requires 6 seconds from 1 track. It would make this transition easier.
B52’s lock shack and deelite groove is in the heart both have points that i want to exit and occasionally, ive been distracted and the track has gone too far.
