Four Deck Full Screen in MacOS (like iOS)
I’ve found a much older, closed topic on something similar, but it’s not quite the same.
  • Device model (2026 Macbook Neo):
  • Version of operating system (macOS 26.5.2):
  • Version of djay (5.6.7):
Is it possible to have a four deck view with the four vertical waveforms on MacOS, but without all the controls and Library showing with it, like you can on the iPad on iOS with lovely, full screen waveforms?
It’s really annoying having so many controls constantly in view, when using a controller. The iOS interface for four deck (hardware mode) is so much cleaner, and you can choose to show the Library or not. So why is this not possible on MacOS as well?
Cheers
James
Good idea @James_Gillies. I’d like this view mode option as well on macOS. I’ve changed this from a Question to a Suggestion so you and others can upvote it. I’ll pass this onto our devs for consideration.
