Macbook Pro
16gb Memory
Sonoma 14.4.1
DJ Pro 5.1.5
Rane 1
Rev 1
When activating the fusion effects there is often an audible pop sound for a fraction of a second when the crossfader is first moved. This happens when crossfader fx and tempo blend is active. This is not always noticible amd seems to be random. I believe it happens more often when using Tidal streaming service however that may not be the case.
Keep up the great work I love the app and use it for gigs everu week.
Can you please provide more details about your MacBook Pro (year, model, chipset, etc.)?
Navigate to djay Settings>Advanced>NEURAL MIX and please take a screenshot of the quality settings.
Please also try to capture a video of this issue, upload it to your Google Drive/Dropbox, enable sharing permissions, and share a link to the video here.
Sorry its M1 Macbook Pro 2021 i believe. I will try and capure the issue and screen shots when I get back home. The software performed perfectly this weekend again as usual at my gigs. This was without using the fusion effects. I generally only use this feature when presenting my radio shows, it is fantastic for this purpose.
