In the latest version of DJay we have the ability to use Fuzzy match to find a compatible song. Couple of questions: 1. Will it search existing library and any streaming services (like Tidal)? When I use it, it only searches Tidal for matches, not my itunes songs that appear in DJay. 2. What is the algorithm used in Djay to find matches with Fuzzy option clicked on?
It would be nice if Matching Songs feature had filters like Fuzzy Matching
The whole point of fuzzy key mixing is that you can adjust the key of any track by only 1 or 2 keys and make it compatible with any other key. I understand what you are asking for, but it doesn’t really apply to fuzzy key mixing.
