2020 iPad Air 4th Gen
iOS 17.5.1
Djay 5.2.3
Is there a way to stop FX D/W setting from resetting to 100% every time
Could it always start at 0% instead?
Searched previous posts and found the issue but no answers.
iOS 17.5.1
Djay 5.2.3
Hi @Neil_Cooper, thanks for sharing the details about your setup. First of all, you need to navigate to the djay Settings>General>SONG LOADING> and make sure Reset EQ, FX, Tempo is turned OFF. After changing this, djay will remember your FX D/W setting when you load the next song.
Thank you, this works, but it isn’t ideal as all settings are kept, so still need to remember to check and change each time. Would be easier if D/W loaded at 0% I.e. Dry each time.
Thanks for your help though. I will try this for a while and see how it goes.
Neil
