Device model (ipad mini 2025):
Version of operating system (ios 26.3.1):
Version of djay (5.6.3):
Hardware/controllers used (e.g. Reloop elite):
Hardware firmware version (1.07):
Please consider sharing a short video or screenshots to help clarify your issue
Hi. I have a problem, and I don’t know how to fix it… My Fx Echo Out/Echo Out+ and a few other effects aren’t working—or rather, they’re acting strangely.
I assigned the SMP FX (aux fx) > Crossfader fx Toggle button in the program, and many effects either don’t work or don’t work correctly!
Could this be because I assigned the SMP FX (aux fx) button?
After playing around with it a bit, I realized it’s better to keep the SMP FX turned off, because they affect the effects even if you don’t map them (are there any ways to use them?)
I recommend you try mapping a different button on a Shift layer for the CFX On/Off toggle. I suspect there is some underlying programming for that SMP FX button that you might be interfering with.
While in the MIDI Learn Tool with the Elite connected to your iPad, simply hold Shift and press the other button you want to map. Then select Crossfader FX toggle from the MIDI options.
EDIT:
Also, I recommend that you first start by making a new edit of the (built-in) MIDI mapping to ensure that you properly revert any unintended changes from your previous edits.
